Cooling a hot engine
Old May 15, 2007 | 01:45 PM
Bibbs's Avatar
Default Cooling a hot engine
Right, after seeing my oil temps getting what I thought were high I want to get the engine running cooler.
Anyone know of a good place to get an
Oil cooler.
Alloy Rad.
Anythink else I should look into?
Thermostat? Rad Cap?
Would i need to getting the AEM remapped with the thermostat? (doesn't the Spoon ECU do something funky if you have the stat?)
Ebay has a cooler for under
Old May 15, 2007 | 01:51 PM
Paper Lawyer's Avatar
Ben, Biker1 has posted about this. Do a quick search mate
Old May 15, 2007 | 01:53 PM
Si2k's Avatar
Thermostat no, stupid idea IMO
Just get an oil cooler and go from there.
Old May 15, 2007 | 01:55 PM
B0ZWELL's Avatar
i take you dont have the aircon rad in front of the coolant rad anymore?
Old May 15, 2007 | 02:02 PM
Bibbs's Avatar
That's who it was .. I think i even posted on it, but I couldn't find the thread ..
Old May 15, 2007 | 02:07 PM
lucky77's Avatar
That Ebay kit doesnt seem to come with a Thermo stat controlled sandwich plate, which with a 19 row cooler i would of though you may want to run. Other wise its never going to get up to temp quick enough on cold days.
Old May 15, 2007 | 02:25 PM
markS2kcU's Avatar
I take it you haven't got the modifry ECT fix yet?
When I had that pulley I thought I was running on the warm side so I changed over to koyo rad, think the main problem I had was the thermostat wasn't opening fully, tested it in a bowl of boiling water with a new J's stat and the one I had didn't hardly open at all.
If you go koyo you might want to think about new fans as well.
https://www.s2ki.com/forums/index.php?showt...0&#entry9948564
With the modifry ECT fix, I run normally 2 bars on the gauge, going to 3 for a little bit if I'm pushing along or stuck in traffic.
Old May 15, 2007 | 10:20 PM
eSeM's Avatar
'$229 shipped' from Invision and payment through paypal
Old May 16, 2007 | 12:11 AM
Bibbs's Avatar
Steven .. Did you get the FAL fans like Mark? Or re-use the stock ones?
Old May 16, 2007 | 12:25 AM
eSeM's Avatar
I am using the OEM fan but I had to file a corner down to get the Mugen intake to fit.
