Dash removal
Old Jul 15, 2012 | 11:59 AM
mattie170's Avatar
Default Dash removal
How big a job is it to remove the dash? I have got a navigation bezel so I can fit my gauges in it but need to take the dash out to fit the backing plate. Unless someone can tell me how to get the backing plate in without removing it.
Cheers
Matt
Old Jul 18, 2012 | 12:18 AM
S2000_FUN's Avatar
Hello Matt,
Do you have a JDM dash or you need to cut your dash to fit the navigation bezel? I am asking because i have cut mine to fit the OEM JDM bezel
Chris
Old Jul 18, 2012 | 12:20 AM
mattie170's Avatar
Need to cut my Uk dash to fit the bezel. Was it a big job?
Old Jul 18, 2012 | 12:31 AM
S2000_FUN's Avatar
It was not as big job as it looked like. The difficult part was to take the right measurements before you start cutting as you cannot make any mistake. I had to buy a spare dash to test it out first and after cut my own dash. We did it together with a friend of mine who has done this before. You also need to cut a smaller hole at the beginning and work the way as cutting it big at the begging might end up having spare space around the bezel. You also need to keep some of the dash material (without the foam which the dash has at the back) close to the edges to glue it at the rear of the dash (i am sorry i do not know how to eplain it in English. I can take any measurements you like from my own dash to help you out, you just have to use them in the oposite way as my car is LHD
Chris
Old Jul 18, 2012 | 01:52 AM
The Loon's Avatar
Search for "dash Cutting club"
Old Jul 18, 2012 | 12:36 PM
mattie170's Avatar
Started the removal now. See how it goes.
Old Jul 18, 2012 | 01:08 PM
BSM139's Avatar
UK Moderator
I need to do this as well.
Post lots (& lots & lots) of pictures please !
Thanks
Bharat
Old Jul 18, 2012 | 01:18 PM
mattie170's Avatar
Will try to if I remember
Old Jul 18, 2012 | 09:14 PM
mr-pitts's Avatar
Thanks
Bharat
+1
Old Jul 18, 2012 | 09:44 PM
S2000_FUN's Avatar
Here are some photos of mine. Hope that helps a bit
http://www.facebook.com/BassJunkies?ref=ts#!/media/set/?set=a.1476757483245.154276.1362981197&type=3
