Diff Oil
Old Jan 23, 2015 | 10:34 AM
dan lewis's Avatar
Default Diff Oil
Hi i am looking for the corretc amount of diff fluid for the s cant seem to find it, have had a quick search and cant find the amount mentioned.
Also which fluid would you recommend and has any one got the part number for the diff washer please.
Cheers Dan
Old Jan 23, 2015 | 10:50 AM
GreenmanS2000's Avatar
It should be in your handbook.
Old Jan 23, 2015 | 11:39 AM
DaGou's Avatar
It takes less than a quart use Amsoil 75W-110
http://www.amsoil.com/shop/by-produc...-gear-75w-110/
You need a pump to get it in. Wrench size is odd too, I think it is like 23mm or something. Do not expect to have it in your tool box. Get the washer from your local Honda dealer, if you think you really need it, he will have the number. On line you can end up paying 10 bucks shipping for a dollar washer.
Here is a pump, you can buy similar at any auto parts store.
http://www.amsoil.com/shop/by-produc...?code=G2039-EA
Old Jan 23, 2015 | 11:49 AM
Doyal's Avatar
Just changed mine recently.
Red Line 75w90 1L
http://www.ebay.co.uk/itm/Red-Line-M...item258b936b0e
Pump
http://www.ebay.co.uk/itm/Transfer-P...p/321327827311
I used a 23mm socket that I chopped in half (depth) to get to the diff fill bolt, it's a bit of a pain.
Old Jan 23, 2015 | 03:40 PM
Chuck S's Avatar
The drain and fill are different bolt head sizes. Good ole' Honda! 23mm and 24mm.
Holds less than a quart. Just keep pumping until it runs out the fill port and then cap it off. Gotta be level when doing this.
-- Chuck
Old Jan 24, 2015 | 12:11 AM
s-2-k-boi's Avatar
Using that technique is fine if the car is level what about if you have the rear of the car jacked up for access
Old Jan 24, 2015 | 12:14 AM
Toms1989's Avatar
You'll get a bit more in than specified which isn't a bad thing.
Old Jan 24, 2015 | 12:35 AM
User 4225's Avatar
Unless you've filled it to the brim, it's nothing to be too concerned about. They take a little under a litre from experience
Old Jan 24, 2015 | 01:22 AM
dan lewis's Avatar
Thanks for the help will be getting it ordered soon along with all other fluids ready for a spring full service
Old Jan 27, 2015 | 08:15 AM
eho's Avatar
eho
I used that pump a few times and the rubber hose connecting to the pump is not very secure, often came loose and spill oil everywhere. I am going to try a new pump next time.
http://www.ebay.co.uk/itm/1713443738...%3AMEBIDX%3AIT
Anyone used this one before?
