Diff Oil
Hi Steph,
I use Motul 90 PA Lubricant limited slip differential (LSD) Extreme pressure, just changed mine again this weekend in fact.
http://www.opieoils.co.uk/p-888-motul-90-p...e-pressure.aspx
Get it from Opie at a good price if you are a S2KUK member (sign up on their site) 2L is enough for two Diff changes.
Would also recommend purchasing one of these if you are doing it yourself -
http://www.halfords.com/webapp/wcs/stores/...tegoryId_165469
- The Nozzle also happens to fit a Honda MTF3 bottle so you can flush the line and use it to do your gearbox oil aswell!
You will also need a 23mm ring spanner to remove the filler bolt (no space for a standard socket)
Other than that you are ready to go!
Enjoy! and welcome!
Chris
Enjoy! and welcome!
Chris
Thanks Guys for that!!While i am the subject of oil has anyone used zx1 as i have had it recommended to me as regards to ware on the TCT, chain and guides so hopefully we don't get all this ticking that i have been reading up on! as it seems to be a common thing.
Also not sure if to put a drop in the Diff too as it is a friction eliminator ?
Steph
