Disconnecting release fork?
Old Aug 31, 2012 | 04:15 AM
Owen_1987's Avatar
Default Disconnecting release fork?
I want to grease where the release fork engages with the release bearing but I don't know how to access that far in. Is it possible to disconnect the release fork to make access easier and simply connect it back up? I don't want to try disconnecting it before I ask for some guidance because i'm worried it won't reconnect and i'll have to pull the gearbox to reconnect it.
Has anyone done this?
Thanks in advance
Old Aug 31, 2012 | 04:26 AM
GaryB's Avatar
You can't pull the fork out with the GB in situ.
Old Aug 31, 2012 | 04:32 AM
Owen_1987's Avatar
Sorry, I wasn't very clear. I mean disconnecting the fork so it's free in the gearbox housing, I know i can't pull it out completley
Old Aug 31, 2012 | 04:39 AM
GaryB's Avatar
Popping it back into place once you disconnect it is very easy. Don't worry.
Old Aug 31, 2012 | 04:44 AM
Owen_1987's Avatar
Thanks for the reassurance, much appreciated
Old Aug 31, 2012 | 09:35 AM
mr-pitts's Avatar
Yes you can, you might find it easier if you take of the slave cylinder.
Old Aug 31, 2012 | 09:51 AM
veehexx's Avatar
done it, it's very straight forward; i found removing slave cylinder is helpful (2x 12mm bolts iirc).
refitting went wrong first time (clutch pedal jammed solid), but re-locating it fixed that. based on that, it would be worth noting the rough angle/position of the fork for when you refit it
shouldnt really take you more than 15-20mins.
Rhop101
Sep 28, 2016 06:02 PM
jkelley
Jul 24, 2014 05:29 PM
ktwenty
Apr 10, 2014 10:21 AM
GoOn3
Jun 20, 2011 04:09 AM
