Dixcel Brake Pads Type Z
Thanks for your review mate, you won't be able to tell the real different before you bedded them in properly.
Just try to go out and brake as hard as you can until the car stop for about 10 times. It will melt the pad deposit on to the disk properly. Then you will be able to feel the real different.
cheers,
Dixon
cheers,
Dixon
Originally Posted by Useful,May 8 2008, 11:47 PM
Make sure you're braking down from as high as poss, too. around 80 should do it.
Eho I'm on OEM discs and they are fine, not planning to try track day speed but jockmeet speed they are just fine
Originally Posted by Dembo,May 9 2008, 01:26 AM
Mine are still going strong, though they still don't feel quite as good as they were before Rockingham. Great when warm, but a little spongey when cold. Definitely worth the cash though.
for the best brake performance please try the Castrol SRF brake oil. This oil have almost no boiling point and its the exact same oil they use in the F1. I use this oil on my own race car and never have soft pedal problem.
Dixon
Originally Posted by Proracer,May 20 2008, 05:44 AM
I think is the oil that cause the soft pedal. Its a common problem with Motul RBF600.
They're not really spongey, it's just lacking the cold initial bite that was so good when new. The pad surface is quite pitted, does that suggest something? I did file off some of the top layer, but it didn't help.
Also I'm a bit concerned that my rears have worn faster than the fronts.
