dodgy rattle
Definately a breaker part IMO. I doubt you'll find a real aftermarket one unless you shell out on a race cat perhaps? but that'll be pointless on it's own as Mike said..
What does it sound like and when does it make the noise?
It sounds like a chattering and seems to appear inbetween 1000-2000RPM, also just before 4000RPM. What other performance parts would be required to make a Decat pipe worth having?
The car has a cold air feed for the intake and a K&N replacement filter at the moment
Anyone recommend any breakers yards?
Thanks for the replies
The cars not under warranty which is annoying. I thought it was the clutch at first but revved it whilst out of gear and the same noise appreared? I read in a previous post this was the best method to test (an in gear rev, and out of gear rev)
So the guy at honda slough has quoted me
Originally Posted by Nick Graves,May 12 2005, 04:41 PM
I would check yourself.
There is a heat shield on top of the cat (obviously!) and the welds break due to vibration/corrosion.
If the gases are OK, just stay in VTEC at all times!
I had this very rattle at about 5k revs and its the heat shield ,I replaced the self tapping screws with a larger size and the rattle has gone ,cost
[QUOTE=hornyhonda,May 12 2005, 05:37 PM] The cars not under warranty which is annoying. I thought it was the clutch at first but revved it whilst out of gear and the same noise appreared? I read in a previous post this was the best method to test (an in gear rev, and out of gear rev)
Thanks for the repies, I shall go with option no.3 then if it is as honda said no.7
Can someone please explain why decatting on a standard car is useless? Ive had a few people say this but nothing to back up what their saying? Im happy to buy a CAI to compliment it if the need be. Are they trying to say decatting on a stock exhaust is pointless? I was also thinking of removing the 1st silencer when getting the decat pipe made up.
What power increases can be expected from a decat pipe and replacement filter?
Im sure my problem above is the heat shield but TBH I have contemplated decatting before so any info on the above questions would be great
Thanks
Thanks
