Downforce
Old Aug 17, 2007 | 02:20 AM
chilled's Avatar
Default Downforce
Are there any proven BGW's (Big Gay Wing) and front bumpers that generate actual downforce without needing an expensive hardtop too?
The CR is nearly out and I know their wing bumper combo is supposed to be for aero, not for looks.
Old Aug 17, 2007 | 02:22 AM
eSeM's Avatar
The Mugen wing works well.
Old Aug 17, 2007 | 02:23 AM
Bibbs's Avatar
Mine works fine .. can defo tell the rear is planted hard.
(but it's no "proven" .. but I was speaking to Chris @ CG about methods to test this using suspension compression at speed)
Old Aug 17, 2007 | 02:39 AM
chilled's Avatar
i thought the Mugen was designed to work in conjunction with the Mugen Hardtop?
Old Aug 17, 2007 | 02:47 AM
eSeM's Avatar
It works best with the Mugen hardtop as that produces the cleanest air at the rear but this would be the case for most wings.
Old Aug 17, 2007 | 02:50 AM
lower's Avatar
PJL's wing obviously provides some downforce as it bent his bootlid!
Old Aug 17, 2007 | 02:52 AM
chilled's Avatar
He's got a hardtop on though, which alters airflow.
Old Aug 17, 2007 | 02:53 AM
Bada Bing!'s Avatar
Banned
Is downforce the same as drag though?
Old Aug 17, 2007 | 02:54 AM
Bibbs's Avatar
It think the HT would smooth the airflow more, so for a soft top, you need one higher (bigger and gayer) in the air flow.
Old Aug 17, 2007 | 02:56 AM
eSeM's Avatar
Problem with a higher wing is a greater chance of bending the bootlid.
(Unless of course you have a CF bootlid ......... )
