Driveshafts
Hey guys, I need a new rear left driveshaft (mines causing vibration I think)
Is there any differences across the model years, I'm confident there isn't but I would like to check first.
Thanks
Simon
Thanks
Simon
Thanks
Simon
Thanks
Simon
As long as the spider is intact, this will net you a good wedge of mileage
Originally Posted by Hypersonik,May 13 2009, 02:07 AM
You could always swap your buckets around.
Did this recently ,as i was getting vibration under acceleration.
Swapped the buckets and problem solved... All that for 40 euros.
And to get an idea .... DIY
P.S: Also fitted driveshaft spacers as the car is lowered and keen to this kind of malfunction.
Thanks for the info.
I have a read about buckets swapping, however I have a whirring noise coming from what sounds like the back left (probably won't be) and would like to rule out the driveshaft (already changed the hub).
Thanks
Thanks
aznives3
Jul 7, 2009 12:33 PM
