Drop link size! Help!
Old Oct 14, 2013 | 06:43 AM
Middlesbrough's Avatar
Default Drop link size! Help!
HI,
I need to order some adjustable drop links ASAP.. i have found thses whitelines ones-
http://www.demon-tweeks.co.uk/perfor...int-drop-links
I think front is 65-75mm and rear is 90-115mm But......
My question is what size bolt diameter is used? 10mm or 12mm????
Thanks,
Old Oct 14, 2013 | 07:01 AM
Carl Bourbon's Avatar
10mm by the looks of that bud
Old Oct 14, 2013 | 07:23 AM
bow1build's Avatar
I ve got both rears oem honda one brand new if its any good for you ?
Old Oct 14, 2013 | 07:37 AM
What makes you think that as you can get the same sizes in the 12mm if you scroll down?
Thanks
Old Oct 14, 2013 | 07:38 AM
Hi,
Sorry mate, they must be adjustable.
Thanks anyway
Old Oct 14, 2013 | 07:51 AM
Thanks
Are you talking about hte parts which bolt to the ARB?
If so it's 10mm because they take 100mm nuts with 17mm heads as that's what I used when replacing my drop links
If you're on about the adjustable part then I'm not sure.
Old Oct 14, 2013 | 08:00 AM
TangoVTEC's Avatar
Originally Posted by Middlesbrough' timestamp='1381765031' post='22826713
[quote name='carl bourbon' timestamp='1381762874' post='22826633']
Thanks
[/quote]
Not to confuse things, but an OEM drop link has a M10 coarse thread, and therefore would take a 14mm headed nut (Japanese) or a 15mm nut. (ISO - European)
If we're not talking about the OEM links, then you may get some nuts which don't have a conventional head size, but the thread must still be 10mm diameter.
Old Oct 14, 2013 | 08:11 AM
WOW.. haha
Yep thats confused me! I have posted the Eibach anti roll bar I have just purchased below
http://www.ebay.co.uk/itm/Eibach-Ant...#ht_1037wt_905
So i know which anti roll bar and I know they are front 65-75mm and rear is 90-115mm overall length. The only thing I dont know is what the bolt diameter is??? it must be 10mm or 12mm? as thats all they stock and i would guess its must be one of these!!
Someone must know!
Old Oct 14, 2013 | 08:27 AM
mdb_75's Avatar
Originally Posted by TangoVTEC
Originally Posted by carl bourbon' timestamp='1381765903' post='22826741
[quote name='Middlesbrough' timestamp='1381765031' post='22826713']
Thanks
[/quote]
[/quote]
The standard head (and nut) diameter for a M10x1.5mm coarse bolt is 17mm so if you purchase nuts to fit the droplinks from a fastner supplier they will be 17mm.
Old Oct 14, 2013 | 08:39 AM
Originally Posted by mdb_75
Originally Posted by TangoVTEC' timestamp='1381766403' post='22826750
[quote name='carl bourbon' timestamp='1381765903' post='22826741']
Thanks
[/quote]
[/quote]
[/quote]
Thought I was right
