ECU Dead?
Further to my earlier post re alarm/immobiliser A friend asked me to do a diagnostic scan to see if any errors popped up. I ran the same ODBII reader & software we have used previously but this time it does not find the ECU - checked every fuse we can find & they all seem ok & there is power to everything.
Is it possible the ECU is the cause of all our issues?
Are these a straight forward swap or is there much faffing with recoding keys etc?
Sorry for all the questions but this car is my son's daily & he desperately needs it back on the road asap.
I think the dash green key is maybe your problem here
https://www.s2ki.com/forums/s2000-el...ircuit-825232/
If you don't get the green key (on dash) I reckon obd is not live.. if needed I can test it tomorrow with mine if it helps
The car has a sensor near the lock which checks out your key. If you don't have the green key I don't think it will talk at all but I could be wrong
https://www.s2ki.com/forums/s2000-el...fault-1215351/
Spoke to H&P - whilst they can't help other than supply a new circuit board fro the alarm, they did confirm it's probably their system preventing the ECU communicating with anything as the immobiliser cuts power to it.
