ECU Reset
Hi
How do I reset the ECU? Sorry the search is still down
Once this has been done is there anything else I will need to do e.g. reset stereo etc? Is it worth giving the MAP sensor a whack at the same time?
Thanks
Ash
Thanks
Ash
Search is back up again now, so I'm not sure why it won't work for you, Ash. Use the search button on the tab at the top, not the box in the top RH corner.
Why are you wanting to reset the ECU....?
Sounds easy enough to do... Is it just the stereo and the clock that will need to be reprogrammed?
Cheers.
Ash
Originally Posted by LLOYDJ,Jul 22 2005, 08:58 PM
Originally Posted by baptistsan,Jul 22 2005, 09:27 PM
New exhaust at a guess.
ECU reset cured problem
