Electric Buffer
Old Aug 11, 2006 | 01:07 AM
Moreno5's Avatar
The temptation is to add a lot, as you think it will be better.
It just annoys me having to wipe off.
Old Aug 11, 2006 | 01:21 AM
BigTed's Avatar
I bought a Halfords one a couple of years ago when I was T-Cutting my old 3-series. It worked a treat. If you do get one, make sure it's not just a plain rotary buffer, but one that has an eccentric motion to avoid massive swirl marks.
(no, not ecentric as in Lord Farqhuar St. John-Smythe, but eccentric as in non-regular).
Old Aug 11, 2006 | 02:35 AM
Nick Graves's Avatar
Originally Posted by rahula,Aug 11 2006, 10:04 AM
I never use a buffer for waxes because it isn't needed. You can wax with carnauba and do the whole car but it will be a lot more difficult to remove it if it is too cold or you apply it too thick. The secret is in applying very thin layers even though the temptation is to apply a lot.
Not sure I get what you mean there:
I tend to apply carnuaba with a wet sponge, in order to thin the layer.
I remove it with the random orbitial, because i'm a lazy can't.
If one applies with the RO you just get tonnes of it everywhere.
Mind you, I get impatient with the sponge & end up putting too much on!
Old Aug 11, 2006 | 03:25 AM
User 11317's Avatar
Old Aug 11, 2006 | 05:45 AM
Xd's Avatar
Xd
You only need a buffer if you are polishing.
Old Aug 11, 2006 | 07:33 AM
Better than putting it on thick; try using 'Pinnacle Crystal Mist' after you've washed it again - it is a very light white Carnuaba spray thet simply wipes off.
Makes it look like you've just done the whole works again, & helps build up that 'wet look' thing.
For a lazy knut like me, it's the way forward!
Old Aug 11, 2006 | 07:56 AM
Fletch's Avatar
What sort of "pad" do you use on buffer when you are polishing with one?
IIRC I've only got a wool type pad and a big bath sponge type effort. That sponge looks a bit dodgy to use on the paintwork.
Old Aug 11, 2006 | 08:20 AM
rahula's Avatar
I use a finishing pad if I use wax with the DeWalt and there is a good trick on how to get paste wax on to it. However, since I don't use the machine for waxing it makes no difference.
Fletch, are you on about the hellfrauds type machine? If you are I have no idea what they come with but I wouldn't use either of the ones you mention or the machine.
Old Aug 11, 2006 | 08:35 AM
JamieS2K's Avatar
I went to hellfords today and they have a cordless polisher in there that doubles up as a car vacuum cleaner for 15 quid. I bet thats good
ivtecsg
Oct 20, 2013 07:56 PM
Nezquick
Car Talk - Non S2000
13
Mar 19, 2011 11:01 AM
iKMTi
Jun 13, 2007 07:57 PM
SHUG
Mar 25, 2007 08:55 AM
melonheadr6
Aug 21, 2006 05:49 AM
