An electrical question re LED's
Old Oct 24, 2013 | 02:51 AM
GaryB's Avatar
Default An electrical question re LED's
Hi.
I'm installing the NOS bottle heater and want to run an LED up to the dash to show when it's switched on.
My plan is this (Excuse the crappy drawing)
What I need to know is, do I need any kind of resistor in line with the LED?
These are the LED's I was going to get.
http://www.ebay.co.uk/itm/12V-Pre-Wi...item19d5f0e55c
Or can anyone think of a better way of getting an LED to light up when the switch is switched on?
Old Oct 24, 2013 | 04:14 AM
unclefester's Avatar
Iluminated switch?
Old Oct 24, 2013 | 04:39 AM
GaryB's Avatar
No cos the switch is hidden under the dash unfortunately.
Old Oct 24, 2013 | 05:04 AM
Dembo's Avatar
You're wiring the LED in series with the relay?
Old Oct 24, 2013 | 05:10 AM
Balashark's Avatar
That seems fine to me
Old Oct 24, 2013 | 05:13 AM
GaryB's Avatar
Not on the 80A leg between the battery and bottle heater. On the leg between the Switched ignition connection, through the switch and into the relay (If that makes sense).
And the LED will be in parallel with that wire. If the LED blows I didn't want that switched line to stop working.
(The relay connection diagram may not be entirely accurate but hopefully you can see what I mean)
Old Oct 24, 2013 | 05:20 AM
GaryB's Avatar
Hopefully this explains it better...
Old Oct 24, 2013 | 05:56 AM
Can't you just wire the switch to the foglight switch instead - or the VSA blank area to the right of the wheel?
Old Oct 24, 2013 | 05:59 AM
GaryB's Avatar
No!
I wanna use the other cool switch they sent me with the red flip up cover!
And I want a goddam LED on the dashboard!
Old Oct 24, 2013 | 06:07 AM
No!
What about one of those GASH flip up top gear sticks and wiring it into the switch on top of that haha
