Electrics
Old Jun 17, 2008 | 01:02 AM
Vixen's Avatar
Default Electrics
Seem to be having a bit of trouble with the electrics. The radio/cd keeps cutting out for no apparent reason and stays off for ages before suddenly working again. I thought this might be something to do with the speakers. Now I'm not so sure.
Also I often lock the doors when I'm in the car and now when I lock the drivers door the passenger door stays unlocked . Central locking works fine.
Sort of thinking I need to check out all the electrics. Is this something I could do myself - with possibly some help from a nice friend or does this sound like a garage job.
Old Jun 17, 2008 | 01:10 AM
gaddafi's Avatar
Banned
no use asking the geeks
Old Jun 17, 2008 | 01:15 AM
ian_6301's Avatar
If it's something simple, like a loose connection or a dodgy fuse, it'll be easy to fix, so you could cheak all the connectors by wiggling them to try to replicate the fault.
Once you have done this, you are into wiring snags, which are notoriously difficult to track down, especially intermittent ones. If you can face the weeks without it and the re-mortgage to pay for it, throw it to a garage.
If not, bodge it till it works and sell it!
Old Jun 17, 2008 | 02:11 AM
Bibbs's Avatar
When the engine is running, check the voltages coming off the battery.
It should be ~14v .. a lot less and you'll have issues (the system runs at 12v, the extra 2 charge the battery) also check the battery terminal connections, and the earth straps.
Is it a stock headunit?
Old Jun 17, 2008 | 02:19 AM
Vixen's Avatar
I've just replaced the battery - is it likely something will be wrong there? Stock headunit, never had it out
Old Jun 17, 2008 | 02:56 AM
Bibbs's Avatar
Is the battery done up properly? A loose connection on one of the terminals would give dodgy problems.
Old Jun 17, 2008 | 03:57 AM
Vixen's Avatar
I'll check later
Old Jun 17, 2008 | 04:37 AM
nomadicS2k's Avatar
Old Jun 17, 2008 | 04:45 AM
Nick Graves's Avatar
The ancilliaries are powered from a separate cable to the +ve terminal.
Check it is clean tight & well-vaselined (oo-er missus!).
Old Jun 17, 2008 | 02:18 PM
RISLAR's Avatar
I agree also check that all wires are correctly fitted, all earths are tight as said above!
