EMS light?
Hi, I put a de cat pipe on yesterday and had no problems. Today the engine management light came on? Could this be something to do with there being no cat? Or should I be worried.. :/
Thanks
Thanks
Ok, so without a sensor it's telling the engine something isn't right.. Ill have to get the garage to sort it out on Monday, this is why I didn't want to do it myself. I'm meant to be going out in it tommorow do you think that's a good idea or is there a possibility it will go into limp mode or something!?
Every owner should have an ebay bluetooth code reader to check codes
You can also reset the light as well if its a code not to worry about.
It took a few weeks for my engine light to come on after fitting a decat. I had the cel (check engine light) fix as well but the later cars are more sensitive.
