engine concern
Just noticed on my new (2nd hand) S2000 a black spot of dirty oil (10 pence piece sized) on the front of the engine in the middle of the aluminum head. I wiped it off and cant imagine where it came from as it is not near any joints and on a vertical surface.
It is directly in the middle of the alley casting below the read rocker cover in an almost dead circular pattern?? I was concerned it was a crack in the head but cant see anything visable. Has anyone else experienced this? If it isnt a fault/leak on the head why would dirt attract here, static?, hot spot?? magnetism??!
I have seen this before on a thread in te US - will see if I can find it.
It was a genuine leak from the head / block but nothing too bad.
I would wipe it off and monitor it...
Can you post a pic?
Can you post a pic?
Just took car to honda Fleet and they are totally confused. They keep saying they have never heard of a porous head but cant explain where the oils coming from! They said that if it is found to be a porous head it would be replaced FOC even as the car is 7 years old
Very strange though, it must be leaking from somwhere. Is it possible that it's being deposited there by being flicked or blown somehow?
A picture here would certainly be worth an awful lot of words.
If it's from the front of the head (the bit by the airbox) then it's not a huge worry as that's just sealing the chaincase - nothing to do with combustion etc.
One possible culprit could be the bolt the timing chain gear pivots on. It's sealed with an o-ring. Note that if it is that do not under any circumstances undo the bolt - the gear and spacers etc would fall into the sump....
-Brian.
-Brian.
