Engine light after oil change today
Old Jan 30, 2011 | 10:47 AM
jimmyb1978's Avatar
Default Engine light after oil change today
made a school boy error today after changing my oil & filter, I unplugged the sensor above the TCT so I didnt damage it when I removed the filter. Forgot to plug it back in when I was idling the car on the drive to warm it up and circulate the new oil.
I noticed the engine light after about 10 mins when I got in to drive off, I knew what I had done I switched it off and plugged it back in.
The light is on now, I have access to a snap on machine but it will take a couple of days to get access to it.
Shouldnt cause a problem driving it with it on for a couple of days will it?
Old Jan 30, 2011 | 11:02 AM
AquilaEagle's Avatar
Administrator
No, won't be a problem, and may well go off of its own accord after driving some miles
Old Jan 30, 2011 | 11:28 AM
jimmyb1978's Avatar
Thanks
Old Jan 30, 2011 | 11:39 AM
Nickamsweet's Avatar
ahh it was the EML... should be good
Old Jan 30, 2011 | 12:48 PM
rob2.2's Avatar
Banned
could try disconnecting the battery for over an hour as that may reset it,
if you have a radio code make sure you have it writen down as you will need it.
Old Jan 30, 2011 | 01:07 PM
Administrator
10 mins should do
Old Jan 31, 2011 | 07:55 AM
andye30m3's Avatar
Isn't there a fuse that you can pull out to reset it?
I think it's one of the 2 larger pink ones just disconnect for a minute or 2. Just make sure you've got the radio code.
Theheff
Feb 13, 2014 10:34 AM
zeroptzero
Jul 18, 2012 05:38 PM
jonjoe
Jul 7, 2005 01:42 PM
gontheg
Jul 1, 2002 09:38 AM
