Engine making nasty noise on startup
Hey folks im in need of some help , iv got a 1999 s2000 which rescently had low millage 2004 engine upgrade as my old one had oil pump failure
. iv noticed on startup only there seams to be a loud screech/rattling noise wich then goes away instantly ! this also happened on my last 99 engine occasionally but is starting to really bug me . anyone heard of this before !
Any help is greatly appreciated
. iv noticed on startup only there seams to be a loud screech/rattling noise wich then goes away instantly ! this also happened on my last 99 engine occasionally but is starting to really bug me . anyone heard of this before !Any help is greatly appreciated
Think it is the starter motor - I had mine replaced under extended warranty and the problem sounds the same as yours. Best way I could describe the sound is like winding up a toy friction car - you know the ones you zoom along the ground a few times and then let go!?!?
That was on a MY04 also.
Cheers
Cheers
You're describing *exactly* an issue I had with my previous car (A3) for 7 of the 8 years I owned it (from new).
It was so common they wouldn't even look at it under warranty - if it's the samr thing it's the starter motor failing to cut out quickly enough. I was worried it would add wear and tear, but 8 1/2 years later it was still going strong, and never failed to start.
My S doesn't do it, HOWEVER if you depress the "Start" button for a second or two a little while AFTER ignition the starter will briefly kick in... while not recommended that you do this often (or for very long) you can check and see if the noise is the same to reassure yourself it's the starter...
Originally Posted by lovegroova,Jun 7 2010, 08:57 AM
Alistair, which dealer did the replacing for you? I only ask as I have an extended warranty. Thanks.
It was Chatham Honda in Abbeyhill in Edinburgh.
No questions asked - took one listen and organised it straight away. Still charged me 1/2 hours labour for 30 seconds diagnosis though :-(
However it was worth it so as not to have the screeching noise every time you fire up.
Cheers
