Engine management light
Old Aug 30, 2011 | 01:55 AM
BigDogsWang's Avatar
Default Engine management light
Hi. I took the Denso sensor off the other day to give it a clean, and now the engine management light stays on. How do I get it off?
Old Aug 30, 2011 | 02:25 AM
s2konroids's Avatar
Search ecu reset.
Pull fuse or take off negative and positive cables from battery and leave off for a couple of minutes.
Old Aug 30, 2011 | 02:57 AM
MB's Avatar
MB
Member
If you took the MAP sensor off, you might have lost the O ring underneath, causing a CEL.
Old Aug 30, 2011 | 03:00 AM
Thanks guys. I made sure the O ring went back in place. Will try the battery reset.
Old Aug 30, 2011 | 06:41 AM
richmc's Avatar
Make sure you have the radio code first, and know how to reset the alarm.
jonybravo78
Jul 4, 2012 05:42 AM
chachaman
Sep 18, 2008 04:04 AM
Putney
Jun 1, 2008 03:25 AM
nambiker
May 27, 2006 08:12 AM
Bibbs
Sep 22, 2005 11:16 PM
