Engine is racing
Old Jun 9, 2009 | 01:46 AM
Mass1979's Avatar
Default Engine is racing
Hi guys,
Got a strange engine problem, which i think is nothing but just wanted to see if anyone else had experienced anything similar and may be able to advise what the cause may be.
When i start the engine from cold, the engine races to 2k, 2.5k revs at idle, only for 5 mins or so. When the engine warms up the idle revs drop back down to 1k or so which is the normal level. This doesn't hqappen everytime i start from cold.
The car was serviced 5k miles ago at Basingstoke Honda and they said she was running perfectly.
Any ideas? Thanks
Old Jun 9, 2009 | 02:00 AM
Sin_Chase's Avatar
Mine does this every cold start in the morning.
I always put it down to some kind of auto choke or to help it warm up a little faster.
Clarity would be welcomed!
Old Jun 9, 2009 | 02:01 AM
Jonsey Boy!'s Avatar
Choke, all cars should do it.
Old Jun 9, 2009 | 02:06 AM
ian_6301's Avatar
"TADTS"
Old Jun 9, 2009 | 02:09 AM
Nick Graves's Avatar
No; the fast idle control should run it @ around 1,500rpm. 2,500 is too fast for no-oil conditions.
Try cleaning the gizzard and check the throttle cable spring is lubricated and all is adjusted.
Failing that, get the dealer to reset.
Old Jun 9, 2009 | 03:08 AM
s2konroids's Avatar
They all idle high, and rich to begin with (from cold) by design.
But 2,500 is far too high.
Old Jun 9, 2009 | 03:19 AM
Sin_Chase's Avatar
Mine sits at 2,000 RPM, but not for very long.
I have to reverse out of my drive in the morning and lets say with a 2,000 RPM idle I have to dip the clutch rather promptly
Old Jun 9, 2009 | 03:58 AM
LadyB's Avatar
or reverse on to your drive at night, then you are facing forwards for the off in the morning ...... fftopic: sorry
2k rpm for a short while, then about 1.5k for a bit longer, if I haven't got around to moving by then!
Old Jun 9, 2009 | 04:44 AM
Sin_Chase's Avatar
Its a private lane and reversing in would be... tricky
Old Jun 9, 2009 | 06:28 AM
jakesalter's Avatar
Mine does it at around 2000rpm for a short period if cold (climatic) and settles down to around 750-900rpm when warm.. I thought a high idle on starting was completely normal (and indeed quite useful).
