failed!
Old Mar 14, 2009 | 03:45 AM
jjr197's Avatar
Default failed!
just failed my mot. front drop link on the anti roll bar is broken! any thoughts on a repair cost?
Old Mar 14, 2009 | 03:47 AM
s2konroids's Avatar
IIRC 60 new
Old Mar 14, 2009 | 03:53 AM
veilsidejonnyo's Avatar
Local auto parts for mine
Old Mar 14, 2009 | 04:03 AM
LTB's Avatar
LTB
Honda will charge you around
Old Mar 14, 2009 | 04:20 AM
U9aXy6Dn's Avatar
if they're rusted they'll be an absolute pig to remove - i'd get the drill out sharpish if it looks like it's seized.
we did my fronts and spent 3-4hours attempting to move the bolt until we got the drill out. took 30mins the other side.
Old Mar 14, 2009 | 05:38 AM
sw20danno's Avatar
Just replaced my drop links all round, as i had 1 snaped rear and 1 snaped front.
The front ones were
Old Mar 14, 2009 | 08:15 AM
jjr197's Avatar
Cheers guys, I'll see about getting both done then.
As always, s2ki comes in with the required info!
Jimi
Old Mar 14, 2009 | 09:25 AM
loftust's Avatar
That's some good advice from sw20danno...I use this method all the time when stripping MX5s. Sometimes they need to be chopped out with a small reciprocating saw.
Old Mar 14, 2009 | 11:28 AM
E4RTH WORM JIM's Avatar
I used an angle grinder on the nuts. I cut a few mm into each one, this made them weak enough to be removed.
Hope you get it sorted.
Mikey81
Jun 1, 2016 02:53 AM
humbucker87
Nov 20, 2013 02:52 PM
AndymacNI
Jun 13, 2011 03:58 AM
Benjamico
Oct 1, 2009 02:46 PM
Paper Lawyer
Sep 5, 2005 01:16 PM
