Faulty seconday o2 sensor
Old Jun 11, 2015 | 06:42 AM
bovril's Avatar
Default Faulty seconday o2 sensor
I got a check engine light last week and pulled the codes: P0138 and P0136
These seem to relate to the secondary o2 sensor looking here: https://www.s2ki.com/s2000/topic/378...-light-thread/
P0138 6 - 3 P0136 ____ Secondary Heated Oxygen Sensor Circuit High Voltage (Sensor 2)
Has anyone else replaced this sensor? Is OEM the best way to go for a replacement?
Or could I disable the sensor as discussed here?
https://www.s2ki.com/s2000/topic/864...o2-sensor-cel/
Old Jun 11, 2015 | 07:30 AM
noodels's Avatar
Got black tape on mine
been on since HFC install
Old Jun 11, 2015 | 08:00 AM
mark_k's Avatar
Yes literally got a replacement one fitted today - the secondary sensor same as you.
I bought a Walker one from www.ecolambda.co.uk after reading a couple of recommendations on here. £66. Job done.
Old Jun 11, 2015 | 11:31 AM
bovril's Avatar
Which one did you buy?
http://www.ecolambda.co.uk/main/ecos...item=250-24121
http://www.ecolambda.co.uk/main/ecos...item=250-24764
Thanks
Old Jun 11, 2015 | 01:09 PM
richmc's Avatar
Consumable item, just like brake callipers.
Old Jun 11, 2015 | 02:07 PM
mark_k's Avatar
I bought the 250-24764, but then I have a MY06. If you have an older one you need the other part I think.
Old Aug 16, 2015 | 03:38 PM
noodels's Avatar
Thanks for the link
Old Aug 16, 2015 | 09:41 PM
flanders's Avatar
Think you can get a Denso one cheaper from here http://www.rockauto.com
Old Aug 17, 2015 | 12:32 AM
noodels's Avatar
Only CAMBIARE VE381270 Lambda Sensor listed bit better saves £8
Old Aug 18, 2015 | 07:08 AM
noodels's Avatar
Got a post CAT Blue Print ADH27045 ordered as white heater wires show 0 resistance and an open circuit
advised about above CAMBIARE VE381270
still could not get 12v supply, ignition on,and not running engine..
Also universal ones seem to be a no no..
