Ferodo strike again
Old Jun 17, 2007 | 11:50 AM
Dembo's Avatar
Default Ferodo strike again
Yep - you can add my EBC disks to the "killed by Ferodo pads" list.
Old Jun 17, 2007 | 11:52 AM
Nottm_S2's Avatar
sh1t...
that's bad.. what happened when it went?
Old Jun 17, 2007 | 11:57 AM
havoc UK's Avatar
Ferodo's? DS2500s? How?!? Are you and the car OK?!?
Old Jun 17, 2007 | 12:26 PM
Dembo's Avatar
Nothing dramatic, just a nasty vibration under braking.
Old Jun 17, 2007 | 12:29 PM
Paper Lawyer's Avatar
Just received my Ferrodo pads...
Old Jun 17, 2007 | 12:30 PM
A7DY W's Avatar
Best order your new discs too then.......
Old Jun 17, 2007 | 12:34 PM
mikey k's Avatar
I'll be avoiding Ferodo then
Old Jun 17, 2007 | 12:36 PM
lower's Avatar
Blimey. Tis starting to look that way. Maybe its a result of the heavy braking aspect of Rockingham.
Any pics? where is the crack?
I'm going to get some new discs for Donington and see how i get on. I certainly didn't crack a disc there last time using the DS2500's.
Old Jun 17, 2007 | 12:51 PM
MB's Avatar
MB
Member
Is it equal to say EBC discs strike again rather than just the Ferodo pads
I dont know the background on this, but seems like 2 of you have had cracked EBC discs, with the Ferodo pads?
Any other type of discs cracked on a Ferodo pad?
While im not a fan of the EBC stuff, the holes appeared to be blind drilled / not straight through - however the ones I have ever seen fail, are right through the holes as per Lower's... Looks like a weakness there to me.
Im putting DS2500 on the DC5 with stock discs for the Ring.
Old Jun 17, 2007 | 12:57 PM
Dembo's Avatar
Not quite as dramatic as Lower's pick.
Lower had spoon disks, Chilled had standard, both cracked at Rockingham with Ferodos. Angelsey was pretty tough on brakes as well (on the plus side I was very impressed with them). Maybe I'd have cracked mine at Rockingham if I wasn't suffering fluid fade all day.
Mine aren't drilled, just dimpled.
