Filter Relocation Plate with Thermostat
Old Sep 21, 2017 | 02:06 AM
Define198's Avatar
Default Filter Relocation Plate with Thermostat
Just looking at my options to adding a oil cooler with filter relocation - need relocation when adding oil cooler due to lack of space because of supercharger.
If i was to do it i would want a thermostat built into the filter relocation, without stacking a sandwich plate on top of the filter relocator.
The only ones i can find seem to be from Greddy, with a 82c thermostat, Which i can only find from japan and would cost around £150. Or one from a company called improvedracing which will probably cost around £300+ with import duties :s But it has the option of a higher thermostat which is what i want.
Am i missing something? Why are their seemingly none available in the uk? Any other options?
Old Sep 21, 2017 | 02:44 AM
s2konroids's Avatar
Try think automotive, they stock them and make up lines etc.
Old Sep 21, 2017 | 03:14 AM
Define198's Avatar
Had not seen that site before, so thanks! but still cant see a filter relocation with built in thermostat?
Old Sep 21, 2017 | 03:16 AM
CynicG's Avatar
Maybe try Tom/TGM also as he sourced/fitted my relocation kit and sensors whilst adding a sandwich plate to the stock location
Old Sep 21, 2017 | 05:09 AM
s2konroids's Avatar
I'm pretty sure that doesn't exist.
Old Sep 21, 2017 | 07:01 AM
Define198's Avatar
It does!
https://frsport.com/GReddy-12401114-...t_p_12814.html
Remote Engine Oil Filter Mount with Thermostat, 215°F, -10AN | eBay
Trouble is like i said, none are in the UK, and the one i want is megga ££ hence the thread asking for any possible alternative
Old Sep 21, 2017 | 07:33 AM
richmc's Avatar
https://www.thinkauto.com/
They do a separate stat so could be paired with a separate relocater is space is a problem.
Old Sep 21, 2017 | 09:26 AM
s2konroids's Avatar
It does!
Remote Engine Oil Filter Mount with Thermostat, 215°F, -10AN eBay
Sorry brain Fart.
I actually have one on my car, a plate over where the original oil filter goes, to a remote filter housing with thermostat built in. As said bought it from think auto!! Ringer them up!
Old Sep 21, 2017 | 09:28 AM
s2konroids's Avatar
https://ibb.co/dk9KB5
Old Sep 23, 2017 | 02:56 AM
tozerman's Avatar
Fairly sure we sell these at work. Will check later for you...
Will this one do ? https://www.bighealey.co.uk/performa...-l-r-ceng689cl
