fitted facelift lights
So i had my facelift lights for a while and decided to fit them. While i had bumper off i might as well remove Egr and airpump and all the junk that goes along with it.
I am by no means a painter just enjoy learning and trying new things. I think it vastly improves the look of the front end.The facelift lights are just much sharper cleaner looking. I done a few thing back to front mesh and lip trim should of went on last but i used Vaseline on the trim so paint wont stick
and just masked mesh
So it begins
Egr and airpump removed.
test fitting lights
fiberglassed number plate holes
Fiberglassed Headlight washer holes
meshed Fitted and secured
Lip rubber trim
First fill of the washer and number plate holes
last fill awaiting sanding
first coat dried indoors curing outside
finished bumper lights fitted,wired and looking good
May spray mesh black later on will wait and let you guys decide
Hope you like it, took many hours and late nights but am happy with the result.
and just masked mesh So it begins
test fitting lights
Lip rubber trim
Cheers guys
Badge had been glued on before i had the car
I'm thinking the same,Black would maybe look cleaner i might just spray it the tomorrow can always spray it back if it looks mince.
i have to take the good with the bad
Looks great with the facelift lights (I am biased), leave the mesh as it is, if you paint it you will be forever touching up stone chips.
This one is really going to fox the MOT testers, different lights and no washers.
