Fluid change
Old Jun 12, 2004 | 11:20 AM
baptistsan's Avatar
Default Fluid change
Am going to change all oils in the car at its first service.
Car is 1 year old on the 17th of July, the same day as I'm doing the Academy day.
Question is should I have her serviced before or after the event?
Old Jun 12, 2004 | 11:25 AM
SNAPPER's Avatar
After . but make sure you're topped up before you set off & take some oil with you.
Old Jun 12, 2004 | 12:53 PM
Spanners's Avatar
Toughie that. Do you let the car handle the higher than normal stresses of a track day on mineral oil that has 9,000 mile of use - and runnin in miles at that, or do you drive the next 9,000 on synthetic that has had a tough first day?
On balance, given this is the time of the switch to synthetic, and the mineral oil has had the added stress of running the engine in then I would change before the track day if it were my car.
I would not be so concerned about the gearbox or diff - I would probably leave those to afterwards.
Old Jun 12, 2004 | 01:08 PM
baptistsan's Avatar
Car wont have 9000 miles on it, a bit under! But I here what you're saying XBy.
Any other opinions?
Old Jun 12, 2004 | 01:12 PM
eSeM's Avatar
From experience I would also go *fully* synthetic.
Old Jun 12, 2004 | 10:04 PM
Busamav's Avatar
I would have it done before without a doubt. No point in ragging an engine on old oil
Old Jun 13, 2004 | 12:04 AM
Bonesy's Avatar
do it before - as above, but also you might find it a bit more 'receptive' on the track day..
bluesaint
Oct 25, 2017 11:54 AM
gofast182
Jul 5, 2011 07:33 AM
alex7
Dec 15, 2006 01:52 PM
spikej
Oct 6, 2004 03:36 AM
axis_of_evil
May 13, 2004 11:04 AM
