Found a rust spot :(
Old Nov 7, 2008 | 08:33 AM
pistonbroke's Avatar
Default Found a rust spot :(
While putting the brakes back on the car today, I found a small bit of rust bubbling up around the rear N/S wheel arch, near to where the bumper meets the panel
Not happy, I hate rust!!
How long is the anti corrosion warranty on the car?, BMW and mercs are over 10 years, surely Honda must be around that.
Old Nov 7, 2008 | 08:39 AM
nomadicS2k's Avatar
Honda is 6, IIRC it was in creased in 2006 to 8yrs....
Either way a 2000 car is well out!
I have lots...
Old Nov 7, 2008 | 10:45 AM
AlyWW's Avatar
I had to take the rubber trim off the rear arches last year and rub down / hamerite then, plaster them in grease and put the trim back on. I only noticed the rust when the bubbles started appearing at the edge of the arches. Mine is 02, enquired at Honda and told no chance of a warrenty claim.
Old Nov 7, 2008 | 11:42 AM
bummer
Old Nov 7, 2008 | 11:51 AM
s2konroids's Avatar
Only way to get rid it to cut out and put a panel in, if you just smooth over it then cover it will come back sooner or later
Old Nov 7, 2008 | 01:47 PM
AlyWW's Avatar
I think I caught mine early enough before the rust took hold. I managed to rub the hole lip down to bare metal before painting and six months on it's not returned. I'm going to re-do it this winter and replace the rubber trim that clamps over it. Plenty of gease to keep the air out. At least nobody can see it hidden under the trim.
Two or three cars I looked at before buying mine had the odd small paint bubble appearing from behind the wheel arch trim.
Old Nov 8, 2008 | 03:54 AM
Paper Lawyer's Avatar
http://www.bilthamber.com/deoxgel.html
As seen here:
http://www.sxoc.com/vbb/showthread.php?t=283826&page=7
Old Nov 8, 2008 | 04:56 AM
cheshire_carper's Avatar
I did warn you. Bloody japcrap always turns into a taxi, sooner or later.
Old Nov 8, 2008 | 04:59 AM
s2konroids's Avatar
PMSL
Jap scrap hehe
Quite a few passat taxis round here
Old Nov 8, 2008 | 05:01 AM
That's through choice, not financial enforcement.
