Front Number plates
So lazy, stupid and thread crash question.....
How do you remove the front plate surround? I've removed the 2 x 10mm screws but it seems to be stuck on. Is there another fix inside or is it likely that a garage may have bonded it?
^^ should come off easily once the two bolts are removed. You tried pulling it gently to see if it'll rock a little? You might then be able to see down the back if there's anything sticking it on.
Not glued mate. There are two bolts holding the plate surround.
I had the same problem. It's a bumper remove job.
Or what I did was cut the plate surround down the middle and it will slide off, and of course you will not be able to use the surround again.
