Front suspension replacement help
Old Aug 8, 2012 | 09:59 AM
lovegroova's Avatar
Default Front suspension replacement help
Well, now I have all the rear suspension bits, I've had the car serviced today and the following has been reported:
Bottom arm bushes split, front top ball joints leaking.
What bits do I need to sort this please
So far I have
15 & 16 (Upper Arms)
24 Lower Arm Bolt x4
31 x2 (Nuts)
32 x2 (Clips)
11 & 12 (Lower Arms)
9&10 (Droplinks)
13
25
28 (bolts etc)
Is that everything?
Thanks as always
Old Aug 8, 2012 | 10:09 AM
razzele's Avatar
Are your castor / camber bushes free?
Old Aug 8, 2012 | 10:40 AM
lovegroova's Avatar
I believe so.
Old Aug 8, 2012 | 11:02 AM
E4RTH WORM JIM's Avatar
Heavy duty ball joints (£80) and poly bushes (approx £50) from Dixon.
Old Aug 8, 2012 | 11:26 AM
razzele's Avatar
I don't think thats LGs angle, he is a stickler for the factory fresh handling and I don't blame him. My car felt great when it was new.
Old Aug 8, 2012 | 12:02 PM
Ultra_Nexus's Avatar
Yeah, heavy duty ball joints for £80 is crazy - he isn't going to be off roading!
Get to your local motorfactor and they'll sort you out.
Old Aug 22, 2012 | 05:04 AM
lovegroova's Avatar
Bump, can anyone help with the bits I need please (just list the numbers)?
Thanks
Old Aug 22, 2012 | 05:23 AM
razzele's Avatar
I'd say the major item missing would be the lower balljoints- I think that's item 4 and the associated nuts.
I'd also consider changing the track rod ends which aren't shown in this picture.
Old Aug 22, 2012 | 08:59 PM
mr-pitts's Avatar
Hi Simon how desperate are you for the parts? If you take into consideration my car is a 09 in the near future I will have a pair of lower ball joints available. I also have the upper wishbones but unfortunately they are poly bushed.ive promised Razz my track rod ends. Let me know and I can give you some idea when they will be off my car.
Old Aug 22, 2012 | 11:31 PM
eSeM's Avatar
Looks like you will already have everything that you need to fix the reported problems.
If nothing is seized it should be a relatively straightforward job to just swap over the parts. Let me know if you need any help with this.
