Fuel Problems?
Old Jan 26, 2006 | 07:03 AM
mr_ninobrown's Avatar
Thumbs up Fuel Problems?
Hey,
Following my recent post about a change in the cars performance
https://www.s2ki.com/forums/index.ph...=345863&hl=lag
After a few tanks of optimax and a map whack or two the problem seemed to go away.
Until this week. Now the only things have changed since before, is that i used the same shell petrol station as i did the first time i had the problem (Optimax of course).
So same thing again, seems to be a lag in the acceleration when you plunk the foot down. The only other thing to recently change is that i put the CAT in on saturday for the MOT
So, is it
1)Dodgy fuel from a dodgy Petrol Station that should be named and shamed?
2) A safe mode related to the CAT being stuck back in??
3) A dodgy MAP and the petrol is a conicednce?
Old Jan 26, 2006 | 07:54 AM
Jel's Avatar
Jel
Slack throttle cable worth checking
Old Jan 26, 2006 | 07:56 AM
As an intermitent problem?
ll have a check, i know there was a post somewhere telling you how to adjust it
Old Jan 26, 2006 | 08:21 AM
Found it..
https://www.s2ki.com/forums/index.php?showt...0&#entry6532301
Try it 2nite if i get the chance
Old Jan 27, 2006 | 08:15 AM
Tightened the throttle cable up...
...Same problem...
...Any other ideas?
Old Jan 27, 2006 | 10:15 AM
AquilaEagle's Avatar
Administrator
New MAP sensor? Cheap from hardtopguy.com
Old Jan 27, 2006 | 11:07 AM
So no one thinks that it could be dodgy fuel?
Old Jan 27, 2006 | 12:33 PM
Bandit_287's Avatar
Mine kangaroos in traffic sometimes..Is that the map sensor on its way out?
Old Jan 27, 2006 | 12:44 PM
euan's Avatar
Its fairly normal for the heat soak to cause this.
If it kangaroos very badly (ie violently and dangerously) then it is a rarer nightmare problem.
Old Jan 27, 2006 | 12:59 PM
Bandit_287's Avatar
No only does it occasinally and not that bad....I just put a bit more revs in an its fine..
