Gear Box Problem
Old Feb 9, 2012 | 12:21 PM
AlexMeineck's Avatar
Default Gear Box Problem
Hi Chaps
My gear box has started to play up.
The Problem.
It crunches changing from 1st to 2nd and 2nd to 3rd gear. Now i got the car serviced on saturday, i asked them to change the gear box oil thinking it would solve the issue. They changed it and it was worse, so i went back and they changed it to 5/30 oil and its better, but not perfect by any means.
It's clear that the syncro's are not up to speed when i change gear, because if i pause for a moment when changing and then slot it into gear, its very smooth meaning the syncro is up to speed.
what would you chaps recommend? If this doesn't solve the problem the car is still under warranty for another 5 weeks so it will go back to get the syncro's replaced.
Please help.....(I have searched but can't fid the answer i need)
Thanks
Alex
Old Feb 9, 2012 | 01:25 PM
richmc's Avatar
Are you serious?!!!!
The gearbox oil is 75W80 the oil you have had put in will kill the gearbox in seconds.
Old Feb 9, 2012 | 01:27 PM
Really, thats what they have put in.
Old Feb 9, 2012 | 01:32 PM
richmc's Avatar
Well whoever put that in get ready to sue them for a new gearbox. Look in the tech FAQ it's all there.
Old Feb 9, 2012 | 01:35 PM
s2konroids's Avatar
I don't think thats quite true Rich, if its SAE 5w30 is equivalent to 70/80. Its GL4/5 you need to worry about.
Old Feb 9, 2012 | 01:36 PM
Dembo's Avatar
That sounds like engine oil. Have you mixed up the numbers?
Old Feb 9, 2012 | 01:38 PM
richmc's Avatar
Definatly not equivelent to 75W80 and it should be GL4, sounds like they have put engine oil in, not good!
Old Feb 9, 2012 | 01:42 PM
Ok, im so glad i asked then.
I will take it to a different garage first thing in the morning to get changed asap.
Thanks so much.
Halfords sell this 75w/80 oil so i will buy 2 litres of this.
Old Feb 9, 2012 | 01:45 PM
hazzaman's Avatar
Go to Honda and get 2 litres of MTF-3
Old Feb 9, 2012 | 01:46 PM
Ultra_Nexus's Avatar
Honda indeed used to recommend engine oil in the gearbox
It's the sulphur that the S2000 box doesn't like (hence why no GL5)
Your synchros are gone i'm afraid and you can change the oil all you want but it won't make any difference.
Claim away!
