Geo problems
Old Jan 25, 2015 | 11:33 AM
mikey k's Avatar
Originally Posted by kahn_v
Originally Posted by mikey k' timestamp='1422180032' post='23480626
Rear toe is not as symmetrical as I'd expect
Has the car ever had a "knock"? It could have a slightly bent control arm?
It has had a front end knock but tom from TGM checked everything and said it's all okay. Guessing Tom would've pointed out any problems
Not sure what he checked but I'd check all the adjusters have the full range of adjustment
Old Jan 25, 2015 | 12:49 PM
markforrester99's Avatar
Another way to problem solve brake issues is a cheap infra red thermometer and measure the disc temperature. They should be similar on the same axle. If one is alot hotter than the other then you know you have an issue. Also when these calipers fail quite often it can be because of poorly lubricated sliders which will leave the outer pad engaging onto the disc so that pad would be thinner than the inside pad.
Honda calipers are known for being crap. When i brought my S2000 i changed the calipers on all 4 corners so i knew where i stood.
Old Feb 14, 2015 | 07:44 AM
kahn_v's Avatar
Hey guys a little update on this. I've since changed all
Four calipers with good condition calipers from a newer car and the rear is still unstable and wonders. It actually feels
Worse than before I had the alignment done at TGM. I don't understand how TGM could have given the car back to me
Like this. Tom explained that when they test customer cars they don't go all out which is fair enough but the instability is noticeable at low speeds too. Any ideas on what can be causing this?
The braking is much improved though as a result of changing out the seized calipers
Old Feb 14, 2015 | 08:03 AM
Nottm_S2's Avatar
Weird
All pressures even
All tyres the same
Alignment done
Not sure what else to check really
51mes's Avatar
Tell me I'm being dumb,
but if your geo is right, your brakes are right, your tyres are right and you're not imagining it ;-) you need to look at your coilovers - are they behaving the same.
1) are they both set to the same adjustment - known this to happen before...
2) is something wrong with one of them?
S.
Old Feb 14, 2015 | 08:07 AM
kahn_v's Avatar
No dude they were purchased brand new from meister r and are still set on their original settings . They've only been on the car for 4 months. Thing is, the car felt unstable even before I installed the coilovers so I know that's not the cause. It's just more noticeable now lol
Old Feb 14, 2015 | 08:08 AM
kahn_v's Avatar
This is a mind f*** lool
Old Feb 14, 2015 | 10:59 AM
mikey k's Avatar
Originally Posted by kahn_v' timestamp='1422210033' post='23480844
[quote name='mikey k' timestamp='1422180032' post='23480626']Rear toe is not as symmetrical as I'd expectHas the car ever had a "knock"? It could have a slightly bent control arm?
[/quote]
Did you look a this?
Old Feb 14, 2015 | 12:23 PM
kahn_v's Avatar
I called TGM they said everything was in check, I'm
Going to call him again to book my car in. It's far from london otherwise I'd been back sooner
Anything in particular to look out for?
Thank you
Old Feb 14, 2015 | 01:14 PM
noodels's Avatar
Subframes loose
diff mount rubbers
faulty differential lsd
halfshafts cv joints
wheel bearings and hubs
front bushes
rack
track rod ends
broken wheel
steering uj
