Geometry
Old Feb 16, 2013 | 02:32 AM
goggy85's Avatar
Default Geometry
Hi Guys,
After abit of advice, i purchased a 2005 low mileage Honda S2000 in Berlina Black at the end of last year. The car is lowered on what appears to be yellow apex springs? possibly 30mm?
I have noticed the tyres have worn on the inside at the front (i replaced the rear not too long ago ad they wore alot better.... should the cars Geo settings be adjusted from standard settings to suit when springs are fitted or are the standard settings ok? I have read on the t'interweb the s2000 runs alot of camber out of the factory for handling purposes? i'm not sure if the previous owner had the Geo done after the springs were fitted.
What advice would you give to reduce the inside tyre wear? Ant recommended geo specialists in the northwest you would recommend or could an average joe garage sort this out?
Cheers for reading.
Craig.
Old Feb 16, 2013 | 03:16 AM
BCA's Avatar
BCA
Sounds terminal, sell the car immediately, cheaply, to me. A BB 05 low miler, nice!
Get geo done and or drive it harder. HTH
Get it done somewhere reputable that knows S2ks.
Old Feb 16, 2013 | 03:18 AM
MB's Avatar
MB
Member
To reduce wear you probably need to know what the geo currently is. It could be camber or toe, or both causing it.
IMO you should have the geo done after fitting springs are the change in height will pull the geo out.
If you get it checked / adjusted, prepare for some bushes to be siezed!
Old Feb 16, 2013 | 04:02 AM
Si2k's Avatar
Too much toe out I imagine. Get the tracking done at least
Old Feb 16, 2013 | 06:43 AM
mdb_75's Avatar
Do this.
s2konroids
Aug 21, 2009 02:00 AM
jimmied
Jul 29, 2005 05:15 AM
Arfiman1
Feb 2, 2005 10:48 PM
F20C_S2k
Jul 26, 2004 07:00 PM
NICK THE GREEK
Sep 6, 2003 12:22 PM
