Geometry Settings...
Just had the geometry done on the S to the revised settings.
The car now seems to slightly pull to the left now... Could this be caused by the difference in the castor (see below)? Should I take the car back to get them to sort out the difference or is this acceptable?
I will double check the tyre pressures tomorrow... Can any one recommend a tyre pressures for Goodyear GSD3s (had these fitted a few weeks ago).
Camber Actual Recommended
Front Left -1
Front Left -1
If you're running 18 or 17" wheels I run at 34PSI. Some prefer 32.
All round that is.
Sorry I don't know enough about geo to say if that would make a difference. Do you have your before settings?
All round that is.
Originally Posted by indigoblue73,Oct 15 2005, 07:04 PM
These are standard 16 inch wheels... They are the same size as the SO2s, how can these be the wrong size?
S02s have more rubber on the road than a standard tyre, you should really run 245s on the rear in F1s (but they don't make them anymore)
let us know
