Gettting alignment done
Originally Posted by lovegroova' timestamp='1363352802' post='22405489
IIRC, You were complaining about a lack of steering feel, so some more caster might help with that. More camber all round will be more what people call "fast road" and will make things a bit more zippy.
Personally I'd go for a bit more rear toe too, if only to get heat into the tyres a bit more quickly up there in chilly jockland!
Front:
Caster 6°05'
Camber -1°00'
Toe 0°00'
Total Toe 0°00'
REAR:
Camber -2°00'
Toe 0°25'
Total Toe 0°50'
No fancy aftermarket bits needed for those settings.
(I take no responsibility if you hate it, in which case try something more like Nick's - as above, there s no "right" answer to this).
Originally Posted by SCZ4' timestamp='1363353110' post='22405498
[quote name='lovegroova' timestamp='1363352802' post='22405489']
Front:
Caster 6°05'
Camber -1°00'
Toe 0°00'
Total Toe 0°00'
REAR:
Camber -2°00'
Toe 0°25'
Total Toe 0°50'
[/quote]
Will do, thanks! I'll let you guys know how it feels.
It took me some persuasion, before LG got it right, of course!
I think less caster gives a far more natural steering feel without the M-B like artificial weight and rubberiness. The sharp turn-in is an S2000 speciality, hence not too much rear toe-in either.
Remember that if you are upping camber, you need to take out a little caster to stop scrubby turn-in too.
I'd also say that the -1°00'/-2°00' camber works brilliantly on 16" but will kill the insides of your 17" dead. Hence why I now am back to OEM camber.
I don't agree with that, my tyres have been on for about 3000 miles and 3 trackdays now and the fronts measure 5mm inside and outside and the rears measure 4mm inside and out. They've worn completely even...
That's interesting Nick.
I'm actually pondering getting my 16s properly furbed and going back to using them after the winters fun on 16s. It certainly improves ride and you'd imagine grip on some of our less than perfect roads. Hmmm
I put a full set of boots on the 17s last year so need to get some use out of those first
For mainly road useage, it's too much. I'm not the first one to discover that, either.
