Got the CEL code
My ODB II reader arrived today so I was able to extract the fault code from the ECU.
The code I got was P0304 which is misfire on cylinder number 4.
So please explain to a divvy like me what the most likely causes of this would be and what I should do in order to rectify matters.
My first thought was to check the plugs, which I haven't done yet as it is pitch black out there.
Any other ideas ?
Thanks in advance.
Any other ideas ?
Thanks in advance.
See link in my thread.
Normally plugs / coil pack / injector / MAP sensor.
Can also be engine related.
If its a code which has been repeating you can systematically move parts (injector / coil / plug) to a different cylinder to see if the code follows.
Cheers Mark, I'll go through all the obvious points in your thread.
I do have Denso plugs fitted so I'll whip them out ASAP and have a look at them, in fact I'll order some NGKs tomorrow.
Does anybody have the part number for the NGK platinum plugs ?
Just seen this on one web site and it looks like the right serial number from memory, can anybody confirm this ?
PFR7G-11S
Cheers.
PFR7G-11S
Cheers.
Originally Posted by Paper Lawyer,Oct 26 2007, 12:41 PM
Which can be ordered from the website linked in my sig
Just ordered 4 x PFR7G-11S this morning and received an email confirming they have already been dispatched.
Total cost was
