halfords battery sets the alarm off
Old Nov 24, 2013 | 07:08 AM
hughs2's Avatar
Default halfords battery sets the alarm off
I bought a new battery from Halfords (HB053), installed it, and the alarm went off non stop. I habe to remove the battery to stop the alarm. I nearly went deaf!
Any ideas how I can fix this?
Old Nov 24, 2013 | 07:10 AM
MSC's Avatar
MSC
Sounds like there is no charge in the battery or its not holding its charge.
I know from experience when a battery fails or wont hold its charge, the alarm goes off until the battery is totally dead. I had this problem when my battery was duff.
Old Nov 24, 2013 | 07:54 AM
aston19uk's Avatar
Check the voltage on your battery. Then take it back and get a replacement.
Old Nov 24, 2013 | 08:30 AM
Peachy's Avatar
Might be worth just checking the CCA. I bought a Halfrauds one last winter when I was in a muddle as they had one sitting on the shelf. The one they supply that is supposedly 'correct for the car' actually has a much lower CCA than the OEM item therefore triggering the alarm on initial start up even though the car does start ok.
Old Nov 24, 2013 | 09:17 AM
Toms1989's Avatar
Their batteries are rated lower because they're measured in a different standard ( EN ) Whereas the OEM one was more than likely ( SAE ) rated which is rated higher.
Give you a rough idea what I am on about.
Old Nov 24, 2013 | 11:00 PM
richmc's Avatar
If you can get your cash back, go to Honda and get the OEM one, spec'ed for the car and reasonable price.
Old Nov 24, 2013 | 11:59 PM
garylythgoe's Avatar
I struggle to see why you wouldn't buy a Honda OEM one, when it's £10 cheaper than a Halfords one?
http://www.hendyperformance.co.uk/pr...y_h31500s3ng54
Old Nov 25, 2013 | 12:13 AM
flybikeslee's Avatar
unless he got trade price
Old Nov 25, 2013 | 12:19 AM
True, in which case it should be very easy to return it!
Old Nov 25, 2013 | 05:49 AM
hughs2's Avatar
Thanks for the replies ... maybe it is the Halfords battery (which is new btw) Although I have had issues with the alarm going off unnecessarily, but that sounds like it was probably due to the old one having low charge. Also I have installed the same battery HB053 a few years ago and it was fine. Maybe they changed that battery spec in the meantime. I think I will go to Honda chiswick and get the OEM. thanks again
