Hardwiring my Origin
Old Sep 5, 2004 | 10:04 AM
AquilaEagle's Avatar
Administrator
Default Hardwiring my Origin
I'm connecting it to C as showed in the pic on the Tech FAQ v2 https://www.s2ki.com/forums/index.php?showtopic=181443
Now on this page http://www.s2000.org/mods/radar/ it says it goes through a fuse.
So do i or dont i need an inline fuse, and if so what Amp fuse?
Cheers
Old Sep 5, 2004 | 10:08 AM
bigfecker's Avatar
Yep, I used an inline fuse.
Also I just realised that I had the laser plugged into the green wire and not the blue, now wonder the infrared test did not work! Its does now.
Old Sep 5, 2004 | 10:15 AM
Paper Lawyer's Avatar
yup, 1 amp inline fuse budgie - Maplins have the holder and the fuse
EDIT: are you butchering the existing cable or adopting the more professional DIY lead approach? you can get a a two corse wire premoulded with the correct AC plug from Maplins too.
Administrator
What Amperage?
Old Sep 5, 2004 | 10:16 AM
Administrator
I think i might have one in the Shed
an evening project tonight perhaps
Old Sep 5, 2004 | 10:17 AM
1 amp., as I said!
Old Sep 5, 2004 | 10:18 AM
Administrator
We simultaneously posted methinks
Old Sep 5, 2004 | 01:26 PM
euan's Avatar
I hardwired a 12v accessory socket (sits in the passenger cargo well net) last week, and it was a real b@gger working under the dash (although I'm not exactly svelte) - getting a ring terminal onto the earth point was VERY tricky.
Old Sep 5, 2004 | 10:28 PM
eSeM's Avatar
I put a second 12v "lighter socket" under my left knee. Cost me ~
Old Sep 6, 2004 | 07:50 AM
xviper's Avatar
Try to find some "T" taps. These make tying into ground connections much easier than using the "ring" type of connectors.
AE, although those 3 empty power taps on the fuse panel are already fused, they are fused via high amperage fuses under the hood (bonnet for you guys). An inline fuse of 1 to 3 amps is always wise for any accessory.
