Headlight flickers then goes off...
Old Feb 16, 2011 | 01:09 PM
r8byb's Avatar
Banned
Default Headlight flickers then goes off...
Hi guys,
just wandering if anyone has had this problem.
My headlight bulb went off a few days ago, when flicking the headlights on the headlight will flicker for a second then go off.
If I turn the headlights off and on again the same happens, flickers but very dimm, then goes off.
Is it more likely to be a ballast than a bulb?
Cheers
Old Feb 16, 2011 | 01:18 PM
Joeh's Avatar
Sounds like a ballast.. check the connections?
Old Feb 16, 2011 | 01:29 PM
Itchy Dick's Avatar
Yeah, sounds like the ballast. I had that problem with a Clio 172 I used to own and it turned out to be the ballast.
Old Feb 16, 2011 | 01:32 PM
r8byb's Avatar
Banned
Bummer, ballasts look expensive!
Old Feb 16, 2011 | 01:38 PM
Joeh's Avatar
You can just disable to OEM ballast and just use a one from ebay.
Old Feb 16, 2011 | 01:42 PM
RobinA3's Avatar
My A3 did the same, turned out to be the bulb. Swap the bulbs from the other side and see if the fault follows the bulb or stays with the ballast.
Old Feb 16, 2011 | 02:05 PM
Ultra_Nexus's Avatar
It's the bulb
Old Feb 16, 2011 | 02:07 PM
s2konroids's Avatar
Originally Posted by Ultra_Nexus,Feb 17 2011, 12:05 AM
It's the bulb
Old Feb 16, 2011 | 02:17 PM
gbduo's Avatar
Never worked with car HIDs but when I did work with HIDs in theatre lighting, that is the exact thing the lamps used to do before they snuffed it.
When you take the lamp out, if there is a load of white crap or you can see a hole/protusion in the glass it's had it.
Not a great picture, but the bulb shape in the lamp will be deformed and much bigger.
Old Feb 16, 2011 | 02:22 PM
r8byb's Avatar
Banned
Thanks for the quick replies I've got two bulbs here so I'll try fit them tomorrow!
