Headlights for Dinner
Old Mar 11, 2006 | 06:13 AM
AquilaEagle's Avatar
Administrator
Default Headlights for Dinner
Dismantled the bumper, got the headlight out and the HID unit - which was full of water. Headlight has some condensation in it, and hairdryering it hasn't done much, so I am taking it apart to give it a proper drying out, and to get the dead spider out of it....
Currently cooking my O/S headlight in the oven at 225 degrees
And I am bricking myself!!!
4 minutes to go
You think it will be ok?
Old Mar 11, 2006 | 06:27 AM
s2uk's Avatar
i very much doubt it ian, but what can you have with it? chips or mash.
Old Mar 11, 2006 | 06:46 AM
Administrator
Well it came apart ok just got to get it back together now
Old Mar 11, 2006 | 07:04 AM
s2uk's Avatar
are they meant to come apart then? thought it was a sealed unit. guess a silicone seal may help keep any water out.
Old Mar 11, 2006 | 09:41 AM
Administrator
Yes it's well known put them in the oven to open them up (clearing corners in the USA)
Well i got them apart ok, and dried out a treat!
Putting them back together was more difficult Especially so as when i put them back in to heat the old silicon seal, before adding my own sealent and putting them together, i managed to slightly melt the top of the rear part of the unit
So it ended up a little mis-shaped. ah well, got it back on the car and it is a bit off, but it will do as a temp fix until i get a new O/S headlamp now.
Old Mar 11, 2006 | 10:05 AM
mikey k's Avatar
You didn't need to split it!
I had this on my old S.
All you had to do was warm it up on a radiator or in the oven (not cook it ) to drive the moisture off. Then seal over the failed seal all round the unit with an epoxy glue!
Old Mar 11, 2006 | 10:07 AM
Administrator
I did, cos there was also a dead spider in there, and he wouldn't come out no matter which way and how vigorously i shook it!!
Old Mar 11, 2006 | 10:10 AM
mikey k's Avatar
That spiders cost you a few
Old Mar 11, 2006 | 10:11 AM
Administrator
yup, but it was a risk i was willing to take
Saved me doing it on a set of 04's to clear the indicator lenses (Which is what i really want)
Old Mar 11, 2006 | 10:14 AM
mikey k's Avatar
I'd like to clear mine but it's not that simple on the 04's
