Heated Convex Side Mirrors?
I'm getting fed up of the blind spot from the drivers side side mirror, and I see convex versions are readily available on the bay (link here - very cheap!) - however, I can't work out whether these would remove the heater element or not? Can anyone shed any light on how the heating works - is it integral to the glass? If so, anyone know of a heated convex mirror?
Cheers |
Found this picture in the on line manual-
https://cimg8.ibsrv.net/gimg/www.s2k...fbaa93381b.jpg the manual talks about the mirror holder, the part at the back of the mirror that clips onto the motor plate in the body, it doesn't show if the heater element is stuck to the mirror or if it's part of the holder, I suspect it is as you don't get an element pattern on the mirror when it's heating. But it would be a brave man who try's to separate the two to find out! Looks like the wire to the heater is shown next to the black arrow. There isn't much info as it's listed as a supplemental part. Text that goes with the diagram Take care not to scratch the mirror.
Originally Posted by richmc
(Post 24418868)
Could try the old favourite for removing stuck on bits, the hairdryer, but I guess it would be difficult to heat the whole of the glass without cracking it.
I fitted the blue convex mirrors. Was too concerned about breaking the OEM lenses so just stuck them on top of them. Surprisingly they still heat up and while giving more of a field of vision, the blue colouring cuts down on headlight dazzle very well. A smart upgrade |
If side mirrors are set properly (if you see the side of the car in them, they are not set properly) there is pretty much zero need for convex mirrors. When I taught teen driving schools, kids (and their parents usually) were amazed when they learned this :p You can add mirror heaters though. Their are various options. However, the s2k gets driven April through Oct mainly so I have never cared on this car. Some have fitted motorcycle grip heaters into side mirrors abd say it works well. Some companies make universal kits for it. |
