heated side mirrors switch question
Old Sep 16, 2010 | 02:52 AM
ttang's Avatar
Default heated side mirrors switch question
hi guys,
i've figured out the part number for heated side / wing mirrors for +MY04.
http://www.hondaoriginalparts.com/honda_ca...&block_03=19258
however, I'm not sure where to hook them up to. I have a MY00 AP1, so I don't even have the rear glass element defrost switch.
from the tidbits of info that i read on a thread in the UK forum, I think the switch is on the same switch as the rear window defrost switch. Can anybody confirm this?
thanks,
Tim
Old Sep 16, 2010 | 03:11 AM
chrisr111's Avatar
That's right, the same button operate the rear window and mirror heater elements.
Part number for the switch is:
35500-S2A-G01
but you will need an MY04+ centre console to fit it.
HTH
Chris.
Old Sep 16, 2010 | 03:30 AM
ttang's Avatar
wow thanks! however, i drive an AP1, which has NO defrost switch, and i think it takes quite an effort to add that switch to an AP1. And since:
- there aren't that many AP1s out there (compared to AP2s)
- fewer that would add the OEM hardtop
- AND that live in a place cold enough that would require the effort to add a defrost switch,
there is quite a lack of information concerning adding a defrost switch.
but knowing this helps a lot! The worse case is that i figure out a way to hook up the defroster circuitry, as i'm sure that the actuator heating element would require a timer switch to operate safely; so it wouldn't be too hard.
I've read that AP1s have a defrost switch in the centre console, but it's still very hard to find info on them. Honda Japan had a AP2 softtop conversion for AP1s that included a switch or something...
anyways, thanks again!
Tim
TheT0nemeister's Avatar
Wow I didn't even realise the S had heated door mirrors!
Old Sep 16, 2010 | 03:42 AM
ttang's Avatar
wow.. actually , in this thread https://www.s2ki.com/forums/index.php?showtopic=742253
there is a picture of the MY00-01 hardtop rear defroster switch!
that's what i need to keep it OEM!
however, i like that place for coins, but now that i know that the switch exists, it's not hard for me to reroute the wires somewhere else for a lighted switch in a place of my own!
Sin_Chase's Avatar
Facelift onwards iirc.
Old Sep 16, 2010 | 05:20 AM
ttang's Avatar
2nd question:
the wiring on this diagram only shows 3 switches (http://www.hondaoriginalparts.com/ho...block_03=19258)
but also, in my North American service manual, i only see 3 wires (see my screenshot)
so my question is this:
How do the heated mirrors get their power for defrosting and control, if there are the same number of wires for the heated version and non-heated version? Wouldn't there be at least one or 2 more wires for additional control signals?
Old Sep 16, 2010 | 07:36 AM
BSM139's Avatar
UK Moderator
Hi,
IIRC, the early models DID NOT have the heated door mirrors, hence the 3 wires.
The later models, had the heated door mirrors, and I think they had 4 wires.
Someone more knowledgeable will o doubt come along & confirm (or not)
HTH
Bharat
Old Sep 16, 2010 | 07:39 AM
keith2.2's Avatar
Not looked at any pics, but;
I have an MY00
It has a Hard Top
It also has a rear screen defrost button, next to the washer jets button.
I still have the cup holder / cubby hole in front of them.
ummm, that is all?
Old Jul 19, 2014 | 02:00 AM
S2hippy's Avatar
Originally Posted by ttang
2nd question:
