Heater Problem
Old Oct 19, 2011 | 03:30 PM
Mad Mart's Avatar
Default Heater Problem
Recently the heater on my S takes a long time to get warm. It used to warm up within a few hundred yards but now it takes a few miles (unless I give it some welly). I was wondering if the stat had stuck open but the engine warms up as usual so I doubt it's that. Any ideas?
Old Oct 19, 2011 | 09:33 PM
S2000_FUN's Avatar
Either the water in the cooling system takes longer time to warm up due to the colder weather or you have bubbles in your cooling system and you need to bleed it
Old Oct 19, 2011 | 11:04 PM
WinFreak's Avatar
Or the valve letting the coolant into your heater matrix is stuck shut, common thing on other Hondas after not using the heating for a while
Old Oct 20, 2011 | 12:28 AM
richmc's Avatar
More than likely your first guess, the stat stuck slightly open and the cold not helping.With the car cold, take the rad cap off and start the car, ought to be no movement in the coolant at first then you'll see it start to "churn around". If it moves from start then as they say, "Roberts your Mothers Brother" new stat.
I had this on my old CRX, quick cheap fix.(as long as you don't buy the stat from Honda!)
Omar46
Feb 26, 2015 08:27 AM
yorkies2k
Nov 15, 2013 11:24 PM
GDM S2K
Feb 10, 2009 04:58 AM
mds2000
Dec 8, 2004 05:34 PM
CRX7
Feb 13, 2004 08:23 AM
