help
Old Aug 31, 2008 | 02:34 AM
muchbinding's Avatar
Default help
soft top will not come up but will go down any ideas please
Old Aug 31, 2008 | 02:41 AM
MB's Avatar
MB
Member
Just leave it up, much less gay
Have you got the hand brake on and are not moving?
Tried it with engine off, but ignition on?
Old Aug 31, 2008 | 03:14 AM
tried it all handbrake on, engine off, ignition on?
Old Aug 31, 2008 | 03:16 AM
MB's Avatar
MB
Member
Might be worth locating the fuse for the soft top.
Old Aug 31, 2008 | 06:15 AM
satsuma's Avatar
If it was the fuse, would that not stop it working in any direction?
My guess would be a bad connection at the switch or the switch itself is faulty (but it's only a guess!)
Old Aug 31, 2008 | 06:39 AM
Plastic Sith's Avatar
At the risk of being an ass, how do you know it goes down but won't come back up????
Can you manually get a top up once it is down?!
Presumably it went down and hasn't come back up since? So could be fuse?
Old Aug 31, 2008 | 09:09 AM
m1bjr's Avatar
Are the windows working?
Put them up and activate the roof switch as normal, do they move?
Old Aug 31, 2008 | 10:09 AM
U9aXy6Dn's Avatar
i've always assumed the reason for the 'handle' type crevasse on the top of the hood was for a hand so you could always pull it up if you lost electrics whilst it was down say, on the side of the road.
If it's not the fuse, try the sensor wires under the handbrake.
Old Aug 31, 2008 | 10:36 AM
i followed the manuals advice to get the top up by disconecting the plug under front passenger dash but then reconected it to find same problem when top was lowered, fuses ok . help will ring honda
Old Sep 1, 2008 | 08:31 AM
FunBox's Avatar
You are using the roof switch and not the volume control right?
Does the handbrake light illuminate when you put the break on??
