HELP! Installing a bluetooth parrot...
I was installing a bluetooth parrot that I got for my birthday, it all seemed to be going well, got everything in place and the parrot was working. Thought I better check the position of the microphone with the engine running, and it wouldn't start!
I pulled the stereo out again and unplugged everything - and it still wont start! Its making a kinda clicking noise when you press the starter button and the dash lights are dimmed when the key is in the ignition.
I've checked all the connections I can see under the dash that I might have knocked but its still not starting.
I have an aftermarket alarm but I'm pretty sure that when the imobilisor is on the starter button does nothing, as a pose to the clicking noise it is currently making.
I'm pretty sure its not a flat battery as the lights come on fine and are bright as always.
Anyone got any suggestions as at the moment the car is effectivley useless!!
Thanks
Thanks
You may have blown a fuse somewhere given you've been doing some wiring! Best check them! Sound slike the starter motor is firing but no fuel pump. can you hear the fuel pump start when you turn the key on?
Try the fuel pump one. Either that or your battery really has gone? Seems a coincidence though...
MB
MB
Originally Posted by Nottm_S2,Apr 2 2006, 06:09 PM
it's the battery.. i'd bet someone else's good money on it. try charging
I've stuck a bit of charge in it now and tested it just now and it started first time. I'll leave it on charge for a bit longer this evening.
Thanks all!
Karl
