Help please.
Old May 19, 2006 | 03:30 AM
Rapid 17's Avatar
Default Help please.
I haven't driven my car for eight days and hadn't planned to use it until Monday next (22nd) so i thought it might be a good idea to start it up and run the engine until it reached the normal running temperature. Whilst doing this the EPS indicator lit up. I turned off the engine and restarted but it was still lit up. When i last drove the car there was no problem. Should i immediately contact the dealer or is there something that i can check first that may be the cause ? Please advise, thanks, Geoff.
Old May 19, 2006 | 03:34 AM
MB's Avatar
MB
Member
Is your speedo working ok?
Your PAS may be disabled. Drive the car over 10 mph in a safe area and see if it goes off.
Normally comes on if the revs have been over 3000rpm for a few mins or the speedo signal is lost, or a sensor failure.
MB
Old May 19, 2006 | 03:54 AM
Lloyd Six's Avatar
Find someone with a Snap-on scanner, get them to tell you what trouble code is sorted.
This info will be important to you.
Old May 19, 2006 | 04:00 AM
MB's Avatar
MB
Member
This isnt the same as a CEL Lloyd.
It will give a code though.
MB
Old May 19, 2006 | 04:15 AM
aldfort's Avatar
I am sure I've heard of this before if you just run the motor without actually driving the car if you see what I mean. Try driving the car and making some steering inputs to see if the ligh goes out. If you do have an real fault the streering will be v heavy.
Old May 19, 2006 | 05:10 AM
Rapid 17's Avatar
Thanks for the replies folks. I have just reversed off the driveway and the steering felt heavy. I then drove a short distance and within seconds the EPS indicator went off and the steering felt normal again. Thanks again, Geoff.
Old May 19, 2006 | 05:20 AM
Lloyd Six's Avatar
Woohooo!!!!
No big main stealer bill
Old May 19, 2006 | 05:44 AM
Rapid 17's Avatar
Originally Posted by Lloyd Six,May 19 2006, 05:20 AM
Woohooo!!!!
It's still under warranty.
Spies
Apr 11, 2013 09:10 AM
bruce_s2k
Apr 13, 2012 12:15 PM
s2kpunk
Dec 31, 2007 01:04 PM
FormerH22a4
Nov 8, 2003 03:43 PM
