Help! Rattling noise
Old Feb 14, 2012 | 04:53 AM
PedroHicken's Avatar
Have people tightened theres up or is this an issue that we will have to live with?
Old Feb 14, 2012 | 05:51 AM
GaryB's Avatar
The bolts can rust holding the heat shield on and drop out. A replacement stainless nut and bolt from your local ironmongers is a 50p long term fix if you can't drown out the noise with your stereo.
Old Feb 14, 2012 | 07:06 AM
jeffers's Avatar
Silly question here but.. where is the cat? Is it at the manifold end of the exhaust or further back towards the back-box.
Old Feb 14, 2012 | 07:16 AM
NineBolts's Avatar
Manifold end.
From inside the car if you look at the transmission tunnel you will see a lump on the drivers side and there isn't one to match on the passenger side. that's where the cat is.
Kneel down next to the driver side door and peer under the car
Old Feb 14, 2012 | 07:24 AM
jeffers's Avatar
Cool, sounds like that could be the source of my rattle then. Hopefully the garage will confirm on Friday
Old Feb 14, 2012 | 08:02 AM
yorkies2k's Avatar
I had a similar rattle, turned out that most of the heat shield bolts were missing.
Old Feb 17, 2012 | 05:15 AM
jeffers's Avatar
Update: garage say its the clutch release bearing and it wont cause any harm, just annoyiong.
Guessing it would be a gearbox out job to replace the bearing?
Old Feb 17, 2012 | 05:28 AM
GaryB's Avatar
Does the rattle go away when you press the clutch pedal?
Old Feb 17, 2012 | 06:49 AM
jeffers's Avatar
My mistake - that garage was talking about a different noise. They're not sure what this one is, doesnt appear to be a heatshield or anything serious. Cars due an MOT/service in a few weeks so will see if it gets any worse and sorted then.
Old Feb 17, 2012 | 08:47 AM
NineBolts's Avatar
it will really start to bug you when you have the roof down.
