high flow cat
CEL lights if you don't have the right tweaks.
Might cause a lean spot
TBH I've run the OEM cat, the Berk HFC and the Berk decat, noticed little or no difference with the cat changes alone other than they made my car run lean between 6-7K RPM.
I now have a Berk decat which would throw a CEL on it's own but I also have the Flash Pro on my ECU and have the 2nd O2 sensor checks disabled, I also have it tuned so I don't get the lean spots caused by breathing mods.
