how does this thing work?
Old May 29, 2009 | 03:27 AM
champion_hero's Avatar
Default how does this thing work?
Found this whilst looking at bits and peices just for ideas on prices..
http://www.modacar.com/products/Honda/S200...+Chamber+A.html
how does it work exactly? What sort of performance gains would one expect to receive - would it feel like a mini-vtec!?
Just inturiged more than anything
Old May 29, 2009 | 03:33 AM
eSeM's Avatar
Stored air = Warmer air
Doubt you would get any sort of gains.
Old May 29, 2009 | 03:37 AM
Survey S2000's Avatar
Looks like a ram air type chamber.
http://en.wikipedia.org/wiki/Ram-air_intake
Not sure if it will perform though.
Old May 29, 2009 | 04:08 AM
NineBolts's Avatar
Their intake is not widely used over here on S2000 but I've seen a few pics of them in Evos etc. For the S2000 they have a two piece system that looks like it's welded together out of bean cans and a Family Circle biscuit tin.
The intake is a box that sits behind the rad it has two or three open sides that have filter elements. So it draws air from the rad rather than the normal intake air path? The second part is the link between the TB and the intake box, this is also another welded box.
no idea if it works but I think there are a load of better thought out and better made systems on the market.
My Webpage
Old May 29, 2009 | 05:43 AM
Dembo's Avatar
What!
So the "resevoir" "stores air" does it? What's in the resevoir when it's empty? Given the volume of air the your car sucks in, exactly how much can be stored and how long can it provide a boost for? And what's wrong with that other air store known as the atmosphere?
Old May 29, 2009 | 05:52 AM
oxhouser's Avatar
the whole point of intake tunning is either as short as possible to eliminate frictional losses (improves top end) or a tunned length to keep velocity up this gives more mid range as it aids cylinder fill close to tdc (the exact length determines where the sweet spot is) this system does neither and puts the air intake close to the rad so its sucking hot air in, save your money
Old May 29, 2009 | 05:53 AM
mikey k's Avatar
No way that will "store" enough air to make any difference.
For it to do that it would have to maintain the pressure in the intake higher than the intake manifold at the flows needed to run the engine.
So IMHO
How does this thing work? = It doesn't
Old May 29, 2009 | 05:54 AM
FistralG's Avatar
Doesn't sound like there is much science behind this device. Still they say there is one born every minute....
Old May 29, 2009 | 06:05 AM
mikey k's Avatar
Especially over the pond
Old May 29, 2009 | 06:15 AM
Have any of you guys seen the buddy club time attack car. That has a ram air system that works well. its a CTR or teg, not sure which.
Do you think something like that would be possible on the S?
Id be interested to find a system that works.
